Кто может проверить комплектацию автомобиля по вин коду?
Тема в разделе "Разное", создана пользователем ArturK, 17 сен 2014.
  1. Muxa
    0101 COMMON 88 PLATFORM P2X
    0201 Common material Common
    10AK INTERIOR CODE Leather,grey,P26L
    1139 EXTERIOR CODE Silver metallic
    1202 EXTERIOR PAINT,TYPE Metallic exterior paint
    1301 CLEARCOAT Standard clearcoat
    2B03 ADDITIONAL HEATER,FUEL Parking heater,diesel with timer
    2C01 EL CAR HEATER Without el car heater
    2D01 CUPE´ VENTILATION Without timer controlled cupé ventilation
    2E01 WASTE HEAT UTILIZER Without waste heat utilizer
    2F01 ACCESSORY ELECTRONIC MODUL W/O accessory electronic module
    2G02 HOSE FOR HEATER Hose for cars with no heater
    2H01 CALLSTART OF PARKING HEATER W/o callstart of parking heater
    2I01 EXTERNAL ALARMUNIT SUPPLY W/o wxternal alarm unit supply
    2J01 HANSDSFREE TELEMUTE FUNCTION W/o telemute function
    3801 TWEETER FRONT DOOR Extra variant, without Tweeter
    3902 SUNVISOR/ILLUMINATION Sunvisor vinyl/2makbel, extra variant
    4101 FMVSS-DECAL/PLATE W/o FMVSS decal/sign
    4201 EuroNCAP Decal if PASS.AIRBA Without EuroNCAP decal
    4302 SUNVISOR PASS.AIRBAG Sunvisor without passenger airbag
    4501 COMMON MATERIAL P26/P24 Common material P26/P24
    4601 COMMON MATERIAL P23/P26/P24 Common material P23/P26/P24
    4602 COMMON MATERIAL P23/P26/P24 Common material P23/P24/P26
    4X18 MARKET CODE Market variant, not for part steering
    5101 ADMINISTRATIVE FOR S-CAR Adm variant for standard car
    5502 MMS PREPARATION W/o MMS-preparation,extra variant
    6211 Q-GLASS 5-DOOR, LEFT Extra variant level 1
    6311 Q-GLASS 5-DOOR, RIGHT Extra variant level 1
    6606 FRONT SHOCKABSORBERS Shock absorbers typ 6
    6806 FRONT STABILISER Front stabiliser bar D=23.5 mm,H
    6912 REAR STABILISER Rear stabiliser bar D=16.0 mm
    6A03 EXTRAVARIANT WHEELUNITS FRONT Extravariant
    6B07 EXTRAVARIANT WHEELUNITS REAR Extravariant
    7101 RADIO Extra variant
    7204 VEHICLE TYPE / POWER TRAIN Extra variant
    7404 VEHICLE TYPE / GEAR BOX TYPE Extra variant
    7501 SOFTWARE STEERING, ECM,IF EOBDExtra variant for steering of software for ECM (EOBD,U BLYSND)
    7601 SWITCH BLOCK PANEL, 7 IN ROW Panel for max 3 switches Extra variant
    7738 FRONT SPRINGS-(weight) Extra variant
    7820 REAR SPRINGS-(weight) Extra variant
    7902 Total weight check Carweight is OK
    8001 CABLEHARNESS COUPE Extra variant
    8104 CABLEHARNESS ENGINE COMPARTMENExtra variant
    8332 CABLEHARNESS REAR Extra variant
    8424 CABLEHARNESS ROOF Extra variant
    8502 FRONT SEAT,LEFT Extra variant
    8604 FRONT SEAT,RIGHT Extra variant
    8701 FRONT SEAT, LEFT HAND SIDE Extra variant
    8801 FRONT SEAT, RIGHT HAND SIDE Extra variant
    8911 EXTRA VARIANT STEERING WHEEL Extra variant
    8B02 GEARBOX/DRIVELINE 5-speed automatic, 2WD and 4WD
    8G01 ADM Family for airbag assemblyAirbag module without snapin
    9104 CUSHION REAR SEAT Extra variant
    9202 SLIDE RAILS, FRONT SEAT Extra variant, std slide rail
    9301 EXTRA VARIANT FLOOR CARPET Extra Variant, floor carpet standard and B-pillar ventilation
    9403 PANEL LH SIDE REAR V70 Extravariant
    9B00 DMU,administrative family Not applicable variant, no parts allowed
    9I00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed
    9J00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed
    9K00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed
    9L00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed
    9M00 ADM.FAMILY FOR MEASURED CARS Not applicable variant, no parts allowed
    9T00 ADM.FAMILY FOR TESTCARS Not applicable variant, no parts allowed
    9U00 Adm. for police cars Not applicable variant, no parts allowed
  2. Muxa
    AC30 VEHICLE MAIN TYPE P26E/L wheel base 2755/2763 mm
    AE03 VEHICLE SUB TYPE XC70 Body type 5-door XC
    AF02 DOORS 5 doors
    AG02 POWER TRAIN AWD 4-wheel drive
    AJ02 POWER TRAIN CAR CONFIG. VARIANT
    AP33 SALES VERSIONS - FOR LISTS Sales version 44
    AS01 STANDARD/SPECIAL VEHICLE Standard car unique material
    C101 STEERING POSITION Left hand drive
    C301 MARKET Europe/Overseas
    C402 MAIN MARKET DECALS/SIGNS Decals outside Nordic
    CB04 ENGINE DYNAMICS/STC 5-cyl diesel engine
    CD01 BIFUEL Not Bifuel
    CE05 GENERAL ENGINE VARIANTS 2,4 l Diesel
    CF06 ENGINE 5cyl/2.4l/4V/TDI 163/340
    CG02 FUEL Diesel
    CN02 RETURN LESS FUEL SYSTEM Without ReturnLess Fuel System
    CO01 EXHAUST SYSTEM Exhaust system, std
    CP08 STARTER MOTOR Startermotor 2,2 KW, Diesel
    CQ08 BATTERY 800 Cold cranking Amp
    CR02 ALTERNATOR Alternator 143A EXEC
    CS01 BUSHING, LINK ARM Hydrualic bushings, link arms
    CT00 ENGINE PAD, FRONT AND REAR Not applicable variant, no parts allowed
    CX01 ENGINE COOLING FAN Engine cooling fan, standard
    DB16 GEAR BOX 5-speed Automatic AWD
    DC02 NEUTRAL CONTROL AUTO.GEAR With NEUTRAL CONTROL function
    DD03 PEDAL ARRANGEMENT Pedal arrangements, standard
    DF02 GEAR BOX TYPE Automatic gearbox
    DG02 SHIFTLOCK With shiftlock
    DH02 GEARTRONIC AUTO GEARBOX Geartronic
    DI04 GEAR LEVER TYPE/KNOB Gearlever knob leather
    DK03 VISCO DIFFERENTIAL Electrical Controlled Limited Coupling AWD (HALDEX)
    DL01 TRANSMISSION OIL COOLER, AUTO Without Transmission Oil Cooler
    DN01 EXTRA AIR TO OIL COOLER,TRANSMWithout extra air oilcooler
    DO02 RADIATOR,TYPE Radiator, high performance
    DP01 START BLOCKING MAN GEARBOX Without start blocking
    DQ02 EXTRA WATER COOLER,FUEL Extra water cooler, lower
    DT23 GEAR RATIO Final ratio 2.65:1
    EB01 AIR CONDITION, REAR Without rear air condition
    EC02 AIRCONDITION With aircondition
    ED05 CLIMATE UNIT Electronic climat control
    EE01 GRADUATION CLIMATE CTRL-IF ECCCentigrade gratiation
    EH01 COIN UNIT Without Coin unit
    EI01 COOLING BOX Without Cooling box
    EK01 B-PILLARVENTILATION B-pillar ventilation
    EL02 SAFETY BELT Stdbelt w/o ALR
    EM02 AIRBAG Airbag
    EN02 AIRBAG TYPE Airbag driver/pass side
    EO03 AIRBAG Airbag driver/pass side
    EP02 AIRBAG,PASSENGER SIDE Airbag, pass side, no cutoffswitch
    EQ01 KNEE RESTRAINT Without Knee restraint
    ES03 OCCUPANT WEIGHT SENSOR Without AOS
    ET04 SIPSBAG, FRONT SEAT Sipsbag, Europe model
    EV01 ROOF HATCH Without Roof hatch
    EX01 SEAT BELT MINDER, PASSENGER Without seat belt minder
    F101 COLOUR PACKAGE,INTERIOR Colour package interior
    F201 COLOUR PACKAGE,EXTERIOR Colour package exterior
    FA01 COLOUR MATCHING INTERIOR Colour matching interior
    FA02 COLOUR MATCHING INTERIOR Colour matching interior
    FA03 COLOUR MATCHING INTERIOR Colour matching interior
    FA04 COLOUR MATCHING INTERIOR Colour coordination interior
    FA07 COLOUR MATCHING INTERIOR Colour coordination interior
    FA08 COLOUR MATCHING INTERIOR Colour coordination interior
    FA09 COLOUR MATCHING INTERIOR Colour matching interior
    FA10 COLOUR MATCHING INTERIOR Colour coordination interior
    FA12 COLOUR MATCHING INTERIOR Colour matching logotype carpets (upperthread)
    FA13 COLOUR MATCHING INTERIOR Colour matching logotype carpets (underthread)
    FA15 COLOUR MATCHING INTERIOR Colour matching carpets
    FA16 COLOUR MATCHING INTERIOR Colour matching standard leather
    FA17 COLOUR MATCHING INTERIOR Colour matching doors
    FA20 COLOUR MATCHING INTERIOR Colour matching thread
    FA21 COLOUR MATCHING INTERIOR Colour matching interior
    FA22 COLOUR MATCHING INTERIOR Colour matching sewing tread
    FA23 COLOUR MATCHING INTERIOR Coolur matching child seat
    FA24 COLOUR MATCHING INTERIOR Colour matching sips wire
    FA25 COLOUR MATCHING INTERIOR Colour matching executive
    FA26 COLOUR MATCHING INTERIOR Colour matching coulisse
    FA27 COLOUR MATCHING INTERIOR Colour matching rear shelf
    FA32 COLOUR MATCHING INTERIOR Färganpassning av interiör
    FA33 COLOUR MATCHING INTERIOR Colourcoordination of interior
    FA34 COLOUR MATCHING INTERIOR Colourcoordination, door insert
    FA37 COLOUR MATCHING INTERIOR Colormatching carpet
    FA38 COLOUR MATCHING INTERIOR Colour matching consealing panel
    FA39 COLOUR MATCHING INTERIOR Colour matching dash board lower
    FA45 COLOUR MATCHING INTERIOR Colormatching, frame keypad
    FA46 COLOUR MATCHING INTERIOR Colour matching interior
  3. Muxa
    FA47 COLOUR MATCHING INTERIOR Colour matching interior
    FA49 COLOUR MATCHING INTERIOR Colour matching interior
    FA51 COLOUR MATCHING INTERIOR Colour matching seat belts 2
    FB01 COLOUR MATCHING EXTERIOR Colour matching exterior
    FB02 COLOUR MATCHING EXTERIOR Colour matching exterior
    FB03 COLOUR MATCHING EXTERIOR Colour coordination exterior
    FK22 COLORS,INT/EXT Grey interior P2X
    FK65 COLORS,INT/EXT Silver metallic
    G101 PROTECTION PLATE CAT Without Prot.plate catalyst
    G501 FILLER PIPE Big filler pipe
    G606 FUELTANK,CAPACITY Capacity 68 litre, DIESEL AWD
    G801 FILLING NOZZLE BIFUEL Without Filling nozzle
    G901 FUEL LEAKAGE DETECTION Without fuel leakage detection
    GC19 CATALYST,TYPE Under Floor Converter,Diesel Stage3
    GD01 EMISSION,AIR ASSIST INJECTION Without Air assisted injection
    GE10 EMISSION,AIR PUMP Without Airpump
    GF04 EMISSION,EGR EGR cooled
    GH01 VARIABLE VALVE TIMES Without variable valve times
    GJ04 EMISSION,EVAP-SYSTEM WITHOUT EVAP-SYSTEM
    GK30 EMISSION CODE CCC/UFC,EGR COLD,EOBD VINpos8=9
    GM02 LEAD RESISTANT LAMBDA PROB Without lead resistant Lambda sond
    GX00 LOAD MODULE ECM Not applicable variant, no parts allowed
    GY12 DIAGNOSTIC SYSTEM OBD for Europe
    IA02 WASTE BIN IN TUNNELCONSOL Waste bin in tunnel console
    IB02 WASTE BIN, FIXPOINT Without Waste bin
    JA01 MAIN LIGHTS, TYPE Europe design
    JB01 HEAD LIGHT, SYMMETRY White right assymetrical, 2xH7 bulb
    JC02 AUTOMATIC DIPPED HEADLIGHT Standard dipped headlight Adjustable
    JF02 HEAD LAMP ADJUSTER Manul headlight adjustment
    JG01 HEAD LIGHT CLEANERS Without Wipers
    JJ04 THEFT PROTECTION BRACKET P28 Without protection bracket side door P28
    JK00 REAR FOG LIGHT, POSITION Not applicable variant, no parts allowed
    JL02 LIGHT SOURCE, STOPLIGHT REAR Light bulb
    JS02 REAR FOGLIGHT,TOWFUNCTION Foglights shut off when trailer is connected, only trailers foglights are running
    JT02 FOGLIGHTS,FRONT IN SPOILER Foglights in front spoiler
    K001 MOBILE OFFICE Without mobile office
    K143 CASSETTE/CD RADIO Casette radio with CD-play, Europe high spec.
    K207 LOUDSPEAKER PACKAGE Loudspeakers side doors, D-panel
    K401 MD-PLAYER P28 Without MiniDisc-player
    K501 AMPLIFIER Without Amplifier
    K601 CD/MD-CHANGER Without CD cables
    K703 REAR VIEW MIRRORS El mirror driver-/passide with memory
    K902 TELEPHONE SYSTEM Telephone system GSM
    KA03 SPEED LIMITATION Speed limitation, 210 Km/h
    KB01 INSTRUMENT CLUSTER KM/H gradation, Europa
    KC02 SPEED WARNING Without Speed warning device
    KD01 HEADPHONE SOCKETS,REAR Without rear headset sockets
    KE03 TRIP COMPUTER Trip computer
    KG02 CRUISE CONTROL Cruise control
    KH01 REAR SEAT ENTERTAINMENT Without RSE
    KI03 TV RECEIVING SET Without TV receiving set
    KJ01 BELT REMINDER Europa type
    KK01 COVER REAR VIEW MIRROR Small cover, for manual retractable mirrors
    KL01 BRAKE CONTROL Without Brake control
    KN02 LOUDSPEAKER,D-POST WITH LOUDSPEAKER D-POST
    KO02 LOUDSPEAKER,FRONT DOOR Loudspeakers front side doors
    KP02 LOUDSPEAKER,SIDE DOOR REAR Loudspeakers rear side doors
    KQ01 MICROPHONE Without microphone
    KR01 LOUDSPEAKER,HATSHELF Without Loudspeakers hatshelf
    KT03 PANEL RADIO PREPARATION Radiopreparation in Centrestack VOLVOradio type HU-XXX
    KU01 CENTRE LOUDSPEAKER,DASHBOARD Without Centre loudspeaker, Dash
    KV04 BASS LOUDSPEAKER LUGG.COMP Without subwoofers lugg.comp.
    KW11 CUPHOLDER DASHBOARD Without Cupholder in Dashboard
    KX02 RTI/TV DISPLAY,DASH RTI/TV display, Dash
    KY02 DIVERSITY ANTENNA, BUMPERS Diversity antenna
    KZ02 TELEPHONE Telephone system
    L001 LOGO, remote control Standard LOGO, remote control
    L102 ALARM / REMOTECONTROLES Alarm, 10 alarm cycles
    L202 LOCK TYPE,CENTRAL LOCKING Blocked lock mode
    L301 ALARM ACT VIA DOORLOCK Without alarm activ with door key
    L401 CHILD LOCK Without Electrical child lock
    L501 PASSIVE ALARM ACTIVATION W/o automatic alarm activate
    L601 RETRIGG ENABLING - IF ALARM Without Retrigg functionality
    L801 LEVELSENSOR-IF ALARM With level sensor
    L901 EXTRA EQUIPMENT-IF VGLA Without unique material
    LA02 REAR VIEW MIRROR,HEATING Electrically heated mirrors
    Andrew.B нравится это.
  4. Muxa
    LB04 REAR VIEW MIRROR,PASSIDE Electrically mirror passide with memory
    LC04 REAR VIEW MIRROR,DR.SIDE Electrically mirror driversidewith memory
    LD01 REAR VIEW MIRROR GLAS,DRIVER Driver rear view mirror, wide angle
    LE02 REAR VIEW MIRROR GLAS,PASS SIDPassenger rear view mirror radius=1400, without text
    LK02 LIGHT IN OUTER MIRRORS Light in outer mirrors
    LN00 TRUNK ENTRAPMENT RELEASE Not applicable variant, no parts allowed
    LP03 CIG. LIGHTER/ASHTRAYS Cigarette lighter, front
    LQ01 PRIVATE LOCK LUGGAGE COMP. Without private lock trunk compartment
    LR02 DARKENED REAR WINDOWS Dark rear glasses
    LT02 GLASSBRAKE WIRE/SENSOR Glassbrake wire in rear glass
    LU01 AUTOMATIC LOCKING Without automatic doorlocking
    LV02 MASSMOVEM. SENSOR-IF ALARM With massmovement sensor
    LX07 GLASS,REAR VIEW MIRRORS Wide-angle radius=1400,withouttext
    LY13 FREQUENCY REMOTE-IF REMOTE 433.92 Mhz,w/o panic function
    LZ03 SECURITY PACKAGE Security pagage 3 (lock & alarm)
    M901 DOOR HANDLE, FRONT Door handle, standard
    MB03 TELEPHONE HANDSFREE Without handsfree phone
    MC04 COUPEFILTER Air Quality System
    MI02 ACKNOWL. SIGNAL LOCK/ALARM LOCK/UNLOCK ACKNOWLEDGE
    MN01 FREQUENCY BAND & STEP,RADI Frequency band and step for EU
    MO06 LANGUAGE DUTCH for instrument and radio
    MP03 WALLET CUSTOMER INFO Standard wallet
    MR01 AUTO UP WINDOW LIFTS Auto up, drivers door
    MS29 INSTRUCTIONS Owners manual German, with warranty book, new owner pages, service directory + road map
    MT05 INSTRUMENT CLUSTER CALIBR. Parameter file for EUROPE
    MU07 SERVICE INTERVAL Service interval 7,20000 km
    N001 SIDE POCKET, TRUNK Without side pocket in trunk
    N102 LUGGAGE NET, STEEL Steelnet
    N201 LUGGAGE NET, TEXTILE Without Luggage net
    N403 LOAD HOLDING TRUNK Load holder,luggage comp. 5 door
    N501 CHILD SEAT/CUPH. ARMREST REAR Armrest standard
    N601 CHILD S-BELT ATTCHM REAR Without attachm child belt
    N706 CHILD SEAT ATTCHM Without child seat attchm
    N801 ATTCHM CHILD SEAT FRONT Without child seat attchm
    N901 CHILD SEATS REAR,OUTER Without outer child seat
    NA01 DOOR PANEL,FRONT Front door panel, standard
    NC15 TRIM PANEL Aluminium (Mesh)
    ND01 EXTRA SEAT Without Extra seat
    NE00 ARMREST,DOORPANEL-IF LEATHER Not applicable variant, no parts allowed
    NF02 HANDBRAKE LEVER Handbrake lever, leather
    NG03 UPHOLSTERY MATERIAL Standard leather
    NH01 PROTECTION VISOR, COMBI INSTR Protection visor, combi instrument, P24
    NI03 DRIVER SEAT Power driver seat with memory
    NJ02 PASSENGER SEAT Manually adj. passenger seat
    NL12 SEAT HEAT CALIBRATION Lowtemp 34C - Hightemp 40C
    NM02 HEATED SEAT Heated seat
    NO01 HEADREST REAR,FOLDING Manually foldable rear head- rests
    NP01 SPLIT REAR SEAT 40-60 split
    NQ03 CENTRE CONSOLE FRONT Standard tunnel console
    NS01 LOCK REAR FLOORLID Without lockable rear floor lid
    NT02 ARMREST FRONT SEAT Front arm rest
    NV03 CUP HOLDER,TUNNEL CONSOL 1 cup holder and ashtray
    NY03 PROTECTION CARPET SET,COUPE Carpet set, leisure
    NZ01 FLOOR CARPETS Floor carpets, standard
    PA01 SUNVISOR, UPHOLSTERY Sunvisor, vinyl
    PB03 MAKEUP LAMP SUNVISOR Illuminated mirror driver/pass
    PE02 12 VOLT OUTLET LUGGAGE 12V outlet in luggage
    PF00 HANDLE TAILGATE 5-DOOR Not applicable variant, no parts allowed
    PI05 FIRST AID KIT First aid kit, type 2 Germany Benelux
    PK01 LOADCOVER,5-DOOR Rear shelf 5-door
    PL01 SUN BLIND,REAR WINDOW Without Sun blind (not executive)
    PM01 SUN BLIND,REAR SIDE DOOR WIN. Without sun blind rear sidedoor
    PN02 INSIDE REAR VIEW MIRROR TYPE Automatic dimning of inside rear view mirror
    PP01 HOME LINK Without Home Link
    R164 RIM A 16' 7Jx16x49
    R522 TYRE DIMENSION 215/65R16
    R607 SPARE WHEEL Spare T135/90R17.
    R701 LOCKABLE WHEELBOLTS-IF ALU RIMWithout lockable wheelbolts
    R823 TYREBRAND Pirelli Scorpion STR
    R913 TYRE CIRCUMFERENCE Rolling circumference 2100mm
    RA04 CHASSIE TYPE Chassi COMFORT, base
    RB01 ACTIVE SUSPENSION Without Four-C
    RC03 BRAKE ASSISTANCE Electrical Brake assistance
    RE02 BRAKES,TYPE 16 inch brake
    RF05 ANTI LOCK BRAKE SYSTEM ABS with Dynamic stability traction controle
    RG01 TYRE PRESSURE MONITORING S Without Tyre Pressure Monitoring System
    RH01 ROADFRICTION DETECTION Without Road friction detection
    RI02 LEVELING SYSTEM Leveling system
    RJ01 EL.VACUMPUMP, REAR BOOSTER Without Electrical vacumpump
    RK07 STEERING WHEEL, MODEL Steering wheel 4 spoke, Type V70 XC
    RU02 STEERING WHEEL Steering wheel, leather
    RV15 STEERINGWHEEL MODULE Satelite for Audio and Telephone
    RW01 ROLL STABILITY CONTROL Without Roll Stability Control
    RX01 STEERING GEAR Steering gear, standard
    SC01 TABLE IN REAR SEAT Without table in rear seat
    SF02 COMMUNIKATION TAXI Without el-cable Taxi.
    T101 EXTRA EMBLEM REAR RH Standard emblem, rear
    T239 ENGINE EMBLEM REAR RH Emblem 'D5 AWD'
    T601 SIDEWINDOWS Hardened side windows
    T702 RAIN SENSOR With rain sensor
    T802 WINDSCREEN Tinted windshield with band
    TE01 SILL MOULDINGS Sill moulding
    TG01 SPOILER REAR Without extra spoiler boot lid
    TI03 FRONT BUMPER Design/protection for bumper
    TJ00 BUMPERS COLOUR MATCHED Not applicable variant, no parts allowed
    TK01 NUMBER PLATE HOLDER Without number plate holder
    TN02 WAIST MOULDING Black waist moulding with shiny insert
    TP03 ROOFRAILS P26L-rails with cross bars
    TR02 BODY KIT Blue coloured body kit
    TS03 WARNING TRIANGLE Warning triangle model 2
    TU02 AIR SEALING Air sealing for std. car
    TV01 AIRGUIDE SPOILER Bumper with airguide
    TX01 MUDFLAPS,REAR Without mudflaps
    TY01 MUDFLAPS,FRONT Without front mudflaps
    TZ08 AIR FILTER Airfilter 5cyl, Diesels
    UB01 TRANSPORT STRAPS Without transport eye
    UD01 BATTERY MAIN SWITCH Without Battery main switch
    UE01 BATTERY MINUS CABLE Battery minus cable, old
    VA02 CONTROL UNIT RTI With control unit RTI
    VB11 CD/DVD-ROM DISC - IF RTI DVD-ROM Europe
    VC01 REM, rear electronic module Low spec REM
    VD04 RTI SYSTEM (OM RTI) ALT. PREP.With control unit, RTI EU
    VE01 NIGHT VISION Without Night Vision
    VF02 AEM PREPARATION AEM preparation (Acessory Electronic Module)
    VG01 VOICE CONTROL Without voice control
    VH01 INTERCOM Without intercom
    VI01 TMC Traffic Message Chann Without TMC
    VJ01 GPS Global Positioning Sys Without GPS
    VK01 INFOTAINMENT SYSTEM Without infotainment system
    VM01 INFOTAINMENT THEFT PROTECTION Without InfotainmentTheft protection
    VP01 PARK ASSISTANCE Without parking assistance
    XA02 MARKET DECALS/SIGNS Decals out Japan
    XA11 MARKET DECALS/SIGNS Decals out Australia
    XA25 MARKET DECALS/SIGNS Decals outside France
    XA40 MARKET DECALS/SIGNS Decals outside Canada
    XA42 MARKET DECALS/SIGNS Decals outside USA
    XA44 MARKET DECALS/SIGNS Decals outside USA & Canada
    XB05 PACKAGES FOR PLATES AND DECALSDecals for MC 18
    XD01 USER PACKAGES For VEC
    XE01 USER EXCEPTIONS Only for VCT
    XE02 USER EXCEPTIONS Only for VCG
    XE03 USER EXCEPTIONS Not for VCT
    XE04 USER EXCEPTIONS Not for VCG
    XE05 USER EXCEPTIONS Only for Thailand
    XE06 USER EXCEPTIONS Not for Thailand
    XE07 USER EXCEPTIONS Only for Malaysia
    XE08 USER EXCEPTIONS Not for Malaysia
    XE10 USER EXCEPTIONS Only for Thai, Mal, Indo, Daqing
    XE11 USER EXCEPTIONS Not for Thai, Mal, Indo, Daqing
    XE18 USER EXCEPTIONS For Indonesia
    XE19 USER EXCEPTIONS Not for Indonesia
    XE20 USER EXCEPTIONS Only for ECT
    XE21 USER EXCEPTIONS Only for ECG
    XI02 DECAL FOR TYRE PRESSURE Tyre pressure decal type 2
    Y805 VIN pos 4 or 7 VIN-code position 4
    Y910 VIN pos 5 eller 8 VIN-code position 5
    YB04 YEAR DESIGNATION LETTER Year des 4 = model year 2004
    YC04 MAX FRONT AXLE WEIGHT 1130 kg, V70 XC 2490 lb (CDN)
    YD10 MAX REAR AXLE WEIGHT 1190 kg, V70 XC 2620 lb (CDN)
    YE29 GROSS WEIGHT 2220 kg, V70 XC 4890 lb (CDN)
    YF21 TRAIN WEIGHT 4020 kg
    YG99 MAXIMUM LOAD Without weight
    YH00 TYRE PRESSURE HEAVY LOAD Not applicable variant, no parts allowed
    YI00 TYRE PRESSURE LIGHT LOAD Not applicable variant, no parts allowed
    YJ01 TYRE PRESSURE SPARE WHEEL Without tyre pressure info.
    YL00 SUPPLEMENTSINFO FOR WVTA-NR Not applicable variant, no parts allowed
    YM22 TYRE PRESSURE HEAVY LOAD, TPM No tyre pressure warning
    YP77 WVTA-NUMBER e4*2001/116*0040*10
  5. Muxa
    Изучай :crazy:
  6. Уругнек
    И правда огонь, раз с такой гирляндой продали
  7. Magnum
    Вот сидухи у волги заебатые и климат работает афиненно.
  8. Che
    Летом продали V70 2001 на мкпп за 2 дня.
    Что бы купить хс90 ушло порядка двух недель))
  9. Paparazzy
    Это как?
  10. Magnum
    Это быстро достигается в салоне установленая температура, после чего она стабильно поддерживается. Воздуховоды сделаны так, что мне хватило их выставить один раз и больше не возвращаться к этому вопросу. На других машинах часто было так, что дует в шею, лицо или ещё куда-то и постоянно надо крутить климат, либо опять перенастраивать воздуховоды. И пассажирам сзади так же комфортно, как и спереди т.к. есть дополнительные воздуховоды.
  11. Magnum
    Мой знакомый тоже продавал V70 2002 года порядка 4 месяцев, в итоге отдал перекупу.
  12. krendilj
    krendilj Member
    18 фев 2013
    Muxa огромное спасибо. Машину еще не купил но из вариантов эта на первом месте. Сегодня в сервис отгоню и если все огонь то это моя следующая лошадка.
  13. krendilj
    krendilj Member
    18 фев 2013
    А выбор на хс пал после полутора лет владения в70. Машина бомба поетому и ушла за 1 день и за немалые деньги. А так у меня все также остается верная е46 и е38 с которой намечены грандиозные планы. А вольва для работы и путешествий будет. И экономно и комфортно.
  14. Magnum
    Значит состояние в70 было афигительное. Хороший вольво найти крайне сложно, а поднимать уставший экземпляр очень дорого.
  15. Che
    Видимо хорошая машина была, или цена)
  16. Paparazzy
    Но в Бмв ведь тоже климат збс. В Ауди и vw да, через опу работает.
  17. Magnum
    #37 Magnum, 10 сен 2018
    Про бмв согласен, всё работает на отлично. Vw, ауди, тойота работает через опу. Причём была в пользовании новая королла 2017 года, с раздельным климатом. У впереди сидящих уже сосульки на носу висят, а сзади сидящим жарко. Ставишь авто режим, дует громко и интенсивно без остоновки, буд-то весь холодный воздух уходит хз куда.
    Устал вкладывать бабки в машину, отдал перекупу за 2к и купил в лизинг новую машину. По итогу вышло то на то.
  18. krendilj
    krendilj Member
    18 фев 2013
    Перекуп падла трубку больше не берет. Явно чтото скрывает раз в сервис не проплаченый ехать не хочет. Поиск продолжается хорошо еще варианты есть.
  19. Magnum
    Было бы как с беднягой на румбуле :green:
