Какой электромобиль выбрать?
  1. NEC
    это банальная ложь.
    Божья роса
  2. Mackie
    "I do not believe there will be a dramatic increase in demand for battery vehicles, and I believe this situation is true globally," Hachigo said. "There are issues with infrastructure and hardware.
    "There are different regulations in different countries, and we have to abide by them. So, it's a must to continue r&d," he said. "But I don't believe it will become mainstream anytime soon."
    Honda CEO Takahiro Hachigo
  3. Mackie
    В целом, забавно наблюдать, как законодательное вязательство крючком с целью спасти промышленность и экономику Европы, становится вдруг гражданской позицией особо одарённых индивидуумов, внезапно озаботившихся вопросами экологии.
    Напоминает сказ о том, как американский промышленник, прознав про богатый ресурсами Урал, приехав на месторождение, никак не мог заставить русских мужиков добывать их, никто не хотел копать шахту и работать под землёй. Всем всего хватало на земле, каждый себе хозяин.
    Но вот стоило промышленнику открыть ювелирную лавку..
  4. NEC
    слишком глубоко, каблучки могут начать что то подозревать
  5. Paparazzy
  6. Nikitagreat
  7. хулиGUN
  8. Paparazzy
    А ведь реальная проблема.
  9. хулиGUN
    #789 хулиGUN, 24 дек 2019
    Flash Battery for EV - 5 Minute Charging
    https://www.store-dot.com/business-units
    Why we believe that EV's will "rule" in the near future? Because of multiple reasons, among them are: energy efficient, being environmentally friendly, performance benefits and reduced maintenance.
    EVs do, however, face significant battery-related challenges: driving range, battery cost, weight and recharging time. While the range, cost and weight have been making significant improvement over the last years, charging time remains a major obstacle to speed up global adoption of EV's.
    Fully recharging the battery pack can take several hours. Even at a dedicated super charging station, you can spend 40 min or more.
    A new-generation battery that charges fully in 5 minutes, providing a range of 300 miles
    StoreDot is developing a new type of electric-car battery consisting of proprietary organic compounds – based on the innovative materials used in its flash battery for mobile devices. The EV flash battery will enable a charging experience which is very similar to fueling a gasoline car.
    The EV flash battery enables full charge in 5 minutes, providing up to 300 miles (480 km) of driving distance, depending on the model of your EV. StoreDot fast charging technology shortens the amount of time drivers have to wait in line to charge their cars, thus also reducing the number of required charging posts in a given charging station.
    Charges an electric car in 5 minutes
    EV flash battery’s remarkably fast charging rate is achieved due to StoreDot’s novel materials and new battery structure. The electric vehicle will have a pack comprising of hundreds of EV flash battery cells that can store enough energy for a full EV range on a 5-minute charge. For a 300-mile car, this translates to 60 miles of travel range on a 1-minute charge.
    EV Flash Battery Cost
    Although the EV flash battery enables the remarkable feature of 5-minute vehicle charging, this will not increase the price of the electric vehicle. As the manufacturing process uses traditional capital equipment, with mostly standard processing, the EV flash battery cost is aligned with Li-ion industry’s cost reduction curve over the coming years, and will benefit the expected economies of scale of the industry as a whole.
    Safe and eco-friendly
    EV flash battery architecture is built with a highly stable electrode structure, and contains materials that are far less flammable and more stable at high temperatures than traditional Li-ion technology. Consumer safe, EV flash battery incorporates a multi-layer safety-protection structure. In addition, flash battery is environmentally safer than a Li-ion battery, utilizing organic compounds and a friendlier aquatic based manufacturing process.
    Technology
    Fast-charging batteries for EV
    Leveraging on the innovation for a new generation of Li-ion cell design, the electric vehicle has a pack comprising of hundreds of EV flash battery cells that can store enough energy for up to 300 miles (480 km) range on a 5-minute charge. This translates to 60 miles of travel on a 1-minute charge.
    StoreDot’s core technology incorporates chemically synthesized organic molecules of non-biological origin. These innovative molecules demonstrate uniquely tunable optical and electrochemical properties, which allow for enhanced performance of energy storage devices.
    LiBs (Lithium-ion batteries) power today both portable devices and EVs. While exhibiting relatively slow charging and discharging capabilities, over time, the internal chemical reactions inside the battery reduce their ability to retain energy. Yet, StoreDot has succeeded in maximizing the charge transfer rate, and has enhanced it to heighten the superior characteristics of FlashBattery.
    LiBs contain inorganic compounds in the battery’s cathode, typically comprising metal oxides or polyanions which are continuously recharged by the insertion of lithium ions. This process limits ionic conductivity, thereby reducing the power density and shortening the battery’s life expectancy. Moreover, the electrolyte used in LiBs is highly volatile and flammable, posing a severe safety risk to consumers, critical especially in electric cars.
    Using a unique multifunction electrode (MFE), StoreDot’s FlashBattery combines two benefits of energy storage solutions, incorporating the high-power rapid-charging rate capability with the high-energy storage ability.
    This optimized charging ability is achieved through an innovative electrode structure containing proprietary organic polymers with Metal Oxide compounds of the cathode that trigger the redox reactions. This solution enables ions to flow from a modified anode to a modified cathode at a speed that is much faster than existing technologies. Together with a proprietary separator and electrolyte, this new architecture delivers a high current and low internal resistance, with enhanced energy density and a prolonged battery life.
    While some battery manufacturers were able to improve only one of the following properties - either increased capacity, fast-charging or extended battery-life - StoreDot’s novel technology has optimized these three parameters simultaneously.
  10. хулиGUN
  11. Mackie
    #791 Mackie, 24 дек 2019
    Бро, прояви немного уважения. Вся суть твоего километрового полотна укладывается в полтора предложения и ничем не отличается от любых других фантазеров за последние 10 лет "вот-вот"
    Che, listerman75, Incore и 2 другим нравится это.
  12. Incore
    Сектантам критическое мышление не свойственно
  13. хулиGUN
  14. Paparazzy
    А как себе во двор поставить зарядку? Речь о многоквартирном доме.
  15. a13x
    договариваешься с владельцами земли и электриками. главное понять - как там потом заряжать. если в многоквартирном, то надо подумать, как ограничить доступ другим, либо, чтобы каждый платил за то, что зарядил
  16. Paparazzy
    Место моё. Другой там никто не встанет. Интересна цена сего мероприятия.
  17. Incore
    Форма собственности какая? Domajama dala?
  18. a13x
    ну важно разобраться - можно ли проводку кинуть через имеющееся подключение или нужен новый счетчик, новое подключение. Если новый, тогда вопрос - есть ли для него место или нужен новый шкаф, ну и все вытекающие. Дальше проводка...
    Есть конкретная цифра, Hausmaster через своего подрядчика посчиали 300 евро просто чтобы кинуть розетку в подземной парковке от имеющегося счетчика. Расстояние 75м. Копать ничего не нужно. Просто из разделительного посещения вытащить новый кабель и оборудовать розетку возле стояночного места.
  19. Archi
    Archi Рыбак
    7 фев 2003
    Рига-Москва
    Мне хаусмастер насчитал за 40м -650€.
    Я с электриком и вызовом из садалес тиклс уложился с материалами в 100:)
  20. a13x
    Цареградцев про электрический дрифт-кар
