Моя Audi 90/2.3E, 136 л.с, автомат, 1991 год
Тема в разделе "Audi", создана пользователем Doctor, 28 апр 2013.
  1. Che
    Там в жизни не было даже 10 секунд.. у однокурсника такая на механике была. Вольво, который по жопометру едет на 9.9 до ста, уезжает сильно очень
  2. Doctor
    Doctor Почётный Пенс
    4 июн 2004
    BMWClub
    Brand Audi
    Model 90
    Submodel 90 (89,89Q,8A)
    Modification 2.3 E (89) (133 Hp)Edit data of this car
    Doors 4Edit data of this car
    Power 133 hpEdit data of this car
    Maximum speed 206 km/hEdit data of this car
    Acceleration from standstill to 100 km/h 9.2 secEdit data of this car
    Fuel tank volume 68 lEdit data of this car
    Year of putting into production 1990 yearEdit data of this car
    Year of stopping production 1991 yearEdit data of this car
    Coupe type SedanEdit data of this car
    Seats 5Edit data of this car
    Length 4480 mm.Edit data of this car
    width 1695 mm.Edit data of this car
    height 1395 mm.Edit data of this car
    Wheelbase 2545 mm.Edit data of this car
    front track 1410 mm.Edit data of this car
    Back track 1430 mm.Edit data of this car
    Minimum volume of trunk 425 lEdit data of this car
    Position of engine Front, lengthwiseEdit data of this car
    Volume of engine 2309 ccmEdit data of this car
    Max power in 5500rpm.Edit data of this car
    Torque 186/4000 N * mEdit data of this car
    Fuel System Multi-point injectionEdit data of this car
    gas distribution mechanism OHCEdit data of this car
    Position of cylinders InlineEdit data of this car
    Number of cylinders 5Edit data of this car
    diameter cylinders 82.5 mm.Edit data of this car
    Stroke in the cylinder 86.4 mm.Edit data of this car
    compression ratio 10Edit data of this car
    Number of valves per cylinder 2Edit data of this car
    Fuel Type A-95Edit data of this car
    Drive FrontEdit data of this car
    Number of Gear (automatic Gearbox) -Edit data of this car
    Number of Gear (mechanical Gearbox) 5Edit data of this car
    Front brakes DiscEdit data of this car
    Rear brakes DiscEdit data of this car
    ABS yesEdit data of this car
    steering type CremaillereEdit data of this car
    Power steering hydraulicboosterEdit data of this car
    Fuel consumption (economy) - urban 11.8 l./100 km.Edit data of this car
    Fuel consumption (economy) - extra urban 6.3 l./100 km.Edit data of this car
    Fuel consumption (economy) - combined 8.3 l./100 km.Edit data of this car
    Weight 1170 kg.Edit data of this car
    Max weight 1630 kg.Edit data of this car
    Tire size 175/70 R14
  3. Владислав
    16 июн 2004
    да перестань, 3 ступенчатый автомат :pens: Она на ручке то из 9 не выйдет!! Но машина хорошая, особенно звук :jack:
  4. Muxa
    Чтобы NG двигатель работал на полную, нужно заменить "лопату" - 054133471BX LUFTMESSER VAG 649.84 Ls.
    Никто этого не делает, система впрыска (механический инжектор) давно работает в аварийном режиме, оттого расход - космос, динамика - никакая.
    2 года назад сняли с производства очень важную деталь - гофру ("черепаху"). Хорошие б/ушные дефицит. Лучше покупать прозапас, пока ещё встречаются такие.
  5. Doctor
    4 июн 2004
    BMWClub
    Совершенно верно. 22 года это не может работать исправно. Добавь к этому замену форсунок,ламбда зонда,удаление катализатора,замену регулировочных шайб распредвала. На выходе получаем исправный автомобиль,который едет,как написано в книжке.
  6. DV
    DV Active Member
    31 май 2008
    #26 DV, 30 апр 2013
    А можно ли ГБО установить на AUDI на мех. инжектор, или очень быстро на бензине перестанет работать?
  7. Muxa
    Я бы не ставил. Навряд ли останешься довольным.
  8. Misanthrop
    Misanthrop Member
    18 авг 2009
    tyres
    в каждом источнике по-разному
    http://avtomarket.ru/catalog/Audi/90/774/
    реально на ручке и есть около 9. никак не 10-11. только не понятно с какой целью этот спор? традиции баварианкара? может с человека ещё распечатку со стенда попросим? :green:
  9. Loudness
    Loudness Человек
    25 июн 2011
    Да успокойся, ей надо обосраться, что бы эти 11.5 набрать, какие там из 9и выйти :lol::lol::lol::lol::lol::lol:
  10. Yuranex
    так там разве не 4ех ступенчатый автомат? :gigi: но факт есть факт,2.3 этот не огонь в плане разгона:hihihi
  11. Loudness
    Loudness Человек
    25 июн 2011
  12. Yuranex
  13. Loudness
    Loudness Человек
    25 июн 2011
    А ты что думал, тут у посонов 9 сек до сотни... и 10ка по городу. Прям компромисс из 80 х годов. Просто потсан чу - чуть переоценил машинку и то что он при 136хп/10кл/3ст.акпп укладываеться в 11-12 сек. уже достаточно не плохо.
  14. Paparazzy
    Факт, на ТДС объезжал 2.3:ok:
  15. Doctor
    4 июн 2004
    BMWClub
    Слезь с бронепоезда, мерсовод.:ivf: Второй раз говорю автомат 4 ступени, с режимом "Sport". Мне в принципе по барабану,"верие или неверие" по расходу в городе. Я и на W124 500E,с выключенным кондеем,летом в городе укладывался в 13.7. Тоже мало кто верил. Можно отжигать на все 26л по городу и по 18.5 на трассе. Вопрос - надо ли так дрючить собственный автомобиль ?
  16. Doctor
    4 июн 2004
    BMWClub
    Audi 90: годы выпуска 1990-1991. Сразу за ней пошел кузов В4.
  17. kid
    kid Member
    21 ноя 2008
    красивый был мерс, с орлом на капоте :bffrb:
  18. Loudness
    Loudness Человек
    25 июн 2011
    Ну значит у тебя 20в 170хп, ибо только он шел с 90 -91 и имел 4ступку.
  19. Doctor
    4 июн 2004
    BMWClub
    Первоисточник,утверждает что у меня четырех ступенчатый автомат,
    который все же разгоняет "бабушку немецкого автопрома" менее чем за 10 сек. Подчеркнуто красненьким. Всю книгу перефоткивать в лом. Напечатано VAG 1990 год.
  20. Т1000
    Т1000 Свой человек
    5 фев 2010
    123 киловата, это и есть где то 170лс
